removing pass side door lock cylinder
SteveC
Post by SteveC »
Ok not sure if this is the right place but my driver side door lock cylinder was froze to the point it couldnt get a key in it after a lot of pb blaster and a few very light taps on a key i got the key to go in a out easy but the problem lies in that it wont turn i can get it to go both directions just a little but it wont lock or unlock the door with the key.
Im pretty sure the key and locks were never changed so do i just need to pull the lock out>??? and if so how would i go about doing this
thank you
Steve
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1971ford
Post by 1971ford »
to get the cylinder out, take the door panel off, reach in the door and remove the clip retaining the cylinder with your fingers, and push the cylinder outside of the doorshell.
-Ryan
SteveC
re: removing pass side door lock cylinder
Post by SteveC »
wow that simple eh?? thanks i shoulda thought about that :doh:
1967 f-100 4x4
1971ford
Post by 1971ford »
yup, nice and easy :thup:
-Ryan
69CSF250
Post by 69CSF250 »
do you use your door locks? on my truck the doors were never locked and the latch greese was somewhat hardend to the point where i could not turn the key at all. what I did was spray downt the door latch with PB Blaster and let it soak in before I started to work the key lock/unlock repeatedly eventualy it freed up and now thery are fine. if you do take your door pannel off i'd spray down the inside of the latch as well... good luck its an easy fix either way...
SteveC
Post by SteveC »
the drivers side i use all the time since the only way to lock it from out side is the key.
I cant use the lock then hold in the butten as i close the door trick...
but i imagine that the pass side was never used. I couldnt even get a key to go in at first.
Probally be easiest to remove the panel since i was wanting to put some sound deadning in there away way.
1967 f-100 4x4
kaptnkaos
Post by kaptnkaos »
Yeah Steve...
It's really easy to remove the lock cylinders.
All of our rigs are set up to have to be locked with the key from the out side...
So if yer thinkin' that's a problem with yer lock set, it isn't.
I really like that feature, it keeps me from lockin' my keys in the rig.
I do that with my van all the time...
I keep 3 or 4 extra keys handy just in case.
One time, I actually locked myself out with 3 spare keys and two slim-jims
locked inside the van... all within view.
It was pouring down rain and the van was running...
That has never happened in my bump... :D
KaptnKA 8) S
rjewkes
Re: re: removing pass side door lock cylinder
Post by rjewkes »
did that with a 77 nova busted oput a window and later found out the P.O. kept a coat hanger under the rear bumper for just such an occurance.
fuelly.com
1971ford
Post by 1971ford »
rjewkes wrote:did that with a 77 nova busted oput a window and later found out the P.O. kept a coat hanger under the rear bumper for just such an occurance.
:lolprev:
kaptnkaos wrote:Yeah Steve...
KaptnKA 8) S
:lolprev:
sorry i just had too, that was some good stuff :D
-Ryan
SteveC
Post by SteveC »
my ltd is that way i always have a coat hanger hidden to get in glad i did one day i was 5 miles from my house and it was running and i locked my self out and had to break into my own car
1967 f-100 4x4
kaptnkaos
Post by kaptnkaos »
that's why I had the slim-jims...
I had always kept one under the back bumper and one under the front...
I had gotten them both out to help someone else and had just tossed 'em in the back seat...
I always keep a spare key in my wallet and have a second set of keys (like a master set that has keys to every rig on it)
it was clipped to my back pack which was sitting on the passenger seat with my wallet in it...
I'd started it up and had gotten out to talk to Ashley Cleveland.
She's a rockin' christian recording artist (singer/guitar player) who I admire greatly.
This happened at her concert...
Ok, so now I felt like I was about an inch tall and kinda just wanted to crawl under the van.
She ended up helpin' me round up a old school wire coat hanger...
it took me about 2 seconds flat to get into the van with it...
so I sorta redeeemed myself... :D
KaptnKA 8) S
SteveC
Post by SteveC »
i was thinking for a minute id have to bust a window beofre i remember that coat hanger trick on older cars
1967 f-100 4x4
kilog55
Post by kilog55 »
so we cant lock ourselves out of our trucks? never tried it myself. i know my driver side lock doesnt turn to lock or unlock but the pass. side does fine.
SteveC
Post by SteveC »
yeah cant lock your self out of these trucks...the trick to hold the button in while closing it after you locked it doesnt work here...
now my next question is how do you get the lock cylinder out of the little piece it is in after you remove it from the door i need to pull mine apart to clean it since its full of gunk
1967 f-100 4x4
Underdog97
Post by Underdog97 »
I've learned to keep an extra key in my wallet for emergency reasons, although I must have a hundred extra locksets and twice as many keys. if indeed you need a new door lock PM me and we can set you up and walk you through changing out the tumblers from your old one into it. Just for information THERE'S NO WAY TO MAKE A MASTER KEY for a Ford lock. there's too many combinations and a 5 pin and 7 pin tumbler set up in them.
