fuel hand problem
- 67RED
fuel hand problem
heys guys maybe someone can tell me why my gas gauge is going over as far as possible. even with a half a tank of gas. thought it might be the sending unit. but i replace it with a good one. and it still not reading right.thanks for any help you guys might give.
steve
Life is 90% how you take it10% what you make it
- floyd67
re: fuel hand problem
might be a bad ground
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
2013 f-150 DD
- basketcase0302
- Thunderfoot
Couple of questions for you...
1. If you unhook the sensor wire from the tank does the gauge go to empty?
2. Do you have the full gauge cluster that has the oil, temp and amp gauge or does it just have the idot lights?
3. If it has all the gauges do they seem to be reading right or a little high as well?
If 1 and 3 are yes then it is your IPVR on the instrument panel needs adjusted or replaced.
- 67RED
thanks guys ill check these out later this evening. on my way to work right now. ill let you know what i find thanks for the info guys.
steve
