A/C question
fonzf100s
A/C question
Post by fonzf100s »
Hi all,
I recently aquired an underdash unit for my '69, it's the dealer installed that goes all of the way across the dash, four vents, like this one,
http://www.fordification.com/galleries/ ... m=24&pos=5
Anyways, can someone tell me where the holes go in the firewall for the hoses? I know they aren't the same as the factory air units that go thru the metal piece(both hoses). Any pics and measurements would be greatly appreciated! Thanks, Fonzf100s
Heyyyyyyyyyy, keep 'em cool, keep 'em on the road!
flyboy2610
re: A/C question
Post by flyboy2610 »
I'll get a pic of where the holes in my firewall are and post then up for you later this evening.
flyboy2610
re: A/C question
OK. Here's your pics. The two holes with the grommets are for the AC hoses. The head of the AC compressor will be a fairly straight shot from the holes.
1971ford
Post by 1971ford »
:eek: over there? weird :?
the ones on my 71 went through that oval grommet on the cowl. the ones on the 69 i think went in the holes right above the heater holes :?
-Ryan
flyboy2610
1971ford wrote::eek: over there? weird :?
Factory AC uses a different position for the hoses than dealer add-on systems do.
fonzf100s
Post by fonzf100s »
Thanks FlyBoy. I have been out of town, but thank you for the pics!
Fonz
carcrafter22
Post by carcrafter22 »
Thats wierd
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
SteveC
re: A/C question
Post by SteveC »
mine looks different as well you can see were they go through right below dads hand
http://s169.photobucket.com/albums/u223 ... 0009-2.jpg
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
flyboy2610
You're welcome, Fonz!
Steve, your AC hose exit at about the same spot on the firewall as mine will, close to the vertical reinforcement on the firewall.
As I said, factory AC units use a different exit location than dealer add on systems do.
fonzf100s
re: A/C question
Post by fonzf100s »
Flyboy,
I am adding the dealer add on unit like yours, would there be a chance of pics of the dryer/condenser fittings? I have to get hoses for mine. Not sure of the size hoses, or if you have an idea I need to hear????? Thanks again for the pics!
Fonz
