Choke cable
Joshpow
Choke cable
Post by Joshpow »
I bought a choke cable from a 67 to use on my 72. The knob of course is the 67 style. I'd like to change the knob if possible. Is the knob removeable? If so, how does it come off. I think I can get a knob from LMC to replace it. I just want to know if it is replaceable and how hard it is. Any info would be great.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
Re: Choke cable
i dotn think you can get a replacement knob. because i know of no way to get either style off of the cable without trashing the cable.
MotorDog
Re: Choke cable
Post by MotorDog »
You could possibly get a 72 knob and inside cable from a 72. Simply pull the knob and cable out of the housing cable and replace it. But, if you're doing that, you just as well get a 72 cable assembly complete and use the entire thing and your problem is over. The knob is not easily replaceable by itself.
What ever happened to the age-old practice of just "Minding Your Own Business?"
Joshpow
Re: Choke cable
Post by Joshpow »
I know there is a replacement knob sold. I just looked in LMC. If I can't, I'll get the one from a friend's bump bus and get the knob and cable out. I'll cut it down and use it in the housing I have. The housing on the bus cable is stretched, so I can't use it.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
Re: Choke cable
ok i looked at the book. i guess you can get new knobs.go ahead and order one. you can probably get the old knob off then. i didnt think it coudl be done. but i havent looked at a choke cable in a while. you probably wont be able to save the old knob though is my guess.
Joshpow
Re: Choke cable
Post by Joshpow »
That'd be no problem if the knob broke. Just wondering if anyone had changed theirs to see if it is a huge undertaking. May just get the cable from the bus for now.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
