engine towers stock 68F250 ??
- zakt
did they offer a big block set of stock towers in a 68 F250? If the biggest was the 390 then Im assuming those wont work for the 460?
Todd
Todd
1972 Ford F350 crewcab
Re: engine towers stock 68F250 ??
No, the FE engine perches will not allow you to bolt in a 429/460. You'll need to get those either from a dentside truck or via an aftermarket kit.
- zakt
will the dent side mounts use the stock 68 tower mounting holes (I bet not but have to ask)
Actually, they do. At least the top holes...I don't specifically recall if they use the existing bottom holes as well, but I'm pretty sure they do. I recall that they're a bolt-on for '70-up trucks which have the crossmember drilled for FE and small-blocks, I just don't recall which set of lower holes they use. If they use the small-block holes, then your '68 crossmember will be missing these holes and you'll have to drill them using the 460 perches as a template, since the small-block wasn't available until mid-69.
In other words, in a worst-case scenerio you simply bolt the perches on at the upper bolts and drill a couple holes for the lower bolts.
- zakt
keith,
Thanx for the info, I'll have to see if I can locate me a set of those
Todd
Todd
i am guessing but maybe a set from a bronco. if they ever had a 460 in them. soem of them probably did. maybe broncograveyard.
- zakt
- zakt
Looks like 73-79 only 2wd offered the 460... and assume those are bolted to the crossmember like the 67-72 so have to get 4x4 aftermarket no matter...
- zakt
Someone has these out of a 79 F250 4x4 with a 400 will these work in the 68F250 for that 460???
They should. But I would wait for someone else to say yes before i bought them. I don't have alot of 460 knowledge but I think they will work. Hope this helps in some way. Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- averagef250
No those will not work. As 4x4's go there are 300/FE mounts period from 65-76 then from 77-79 the 351M/400 frame stand was introduced. Those are an inch shorter than the earlier mounts, but will not work for a 429/460 with any sort of factory rubber mount.
460's never came in 4x4's before 1980. They don't really fit that well in the earlier 4x4 trucks, probably why they were never offered.
If you want a 460 in one you need to buy aftermarket rubber conversion mounts for the frame stands you have or buy aftermarket frame stands. The L&L stands are notorious for breaking and coming apart so I would avoid those. Autofab's look pretty good, probably a much better option.
