AM Radio removal
69f100blueangel
AM Radio removal
Post by 69f100blueangel »
I have a 69 F100 and all the interior components work EXCEPT the radio. Does anyone know how to troubleshoot this, or where the fuse for the radio is/ I am even thinking about taking it out and hooking it up to an alternative source to check its functionability. Only problem is I am unsure of how to remove it without damaging other dash parts, or what to remove to get to the mounting bolts. Thanks Derek
Re: AM Radio removal
it has an inline fuse on some models. other models the fuse is in the fuse box.. to remove it you might need to take out the glove box. but start at the front taking off the knobs nuts and bezel. there is also a rear bracket that can be unbolted from underneath the dash. its a 7/16 socket.
69f100blueangel
Nice!!! Im going to get to work. Thanks alot fordman.
