Dana 44HP headers
4x4 & Off-road Forum Archives
Moderator: Doug Comer
Doug Comer
Dana 44HP headers
Post by Doug Comer »
My cousin is fixing up his 68 highboy. I've been helping ALOT. He picked up a set of headers form a 74 f-100 4x4. This truck has a high pinion front axle. We are in the process of rolling a 78 dana 44 high pinion under his truck. He wanted me to ask you guys if these headers will fit. I'm kinda on the fence on this one. :hmm: Thanks for your input. Doug
1967 f100 4x4
1970 f250 4x4
CO684X4
Re: Dana 44HP headers
Post by CO684X4 »
Shouldnt be a problem a HP dana 44 is a HP dana 44 if it fit in the 74 should work fine in the 68.
Thunderfoot
Post by Thunderfoot »
I'm curious to see how this works out just from the standpoint of the headers were for an F100 4x4 and you are putting them on an F250 4x4... When looking at headers for my Highboy they showed different part numbers between models and they are constructed different :dk: if they will work because of that... but the High Pinion part shouldn't make any difference as the headers aren't close to the center section anyway and the axle tube are still in the same place. :2cents:
Doug Comer
The problem I ran into was the collectors hit the driveline on the HP. Thats why I had to run blockhuggers. :?
Doug
1967 f100 4x4
1970 f250 4x4
Doug Comer
Header colectors hit the driveline. :roll:
Doug
1967 f100 4x4
1970 f250 4x4
