Door Locks
JMcTurnan
Door Locks
Post by JMcTurnan »
When I lock my door from the inside and shut the door is it suppose to open?
TheEskimo
Re: Door Locks
Post by TheEskimo »
You mean unlock when you close the door? Yeah, at least mine does. They have to be locked from the outside with the key. Keeps you from locking the keys inside.
-Jason
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
JMcTurnan
Re: Door Locks
Post by JMcTurnan »
Alright just making sure, my key doesn't lock the driver side door for some reason. I think the rods are hooked up wrong, or something. But it does like passenger side.
1982 flareside
Re: Door Locks
Post by 1982 flareside »
I beleve all ford tuck are supprose to do that. Dodges and chevys dont.
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
Re: Door Locks
it could be the lever on the backside of the lock is broken. they are famous for that. i have seen many of them break. they things are made of potmetal. so they don't last forever.
JMcTurnan
Re: Door Locks
Post by JMcTurnan »
Where can I get that lever? Is it on the lock itself or a rod?
basketcase0302
Re: Door Locks
Post by basketcase0302 »
JMcTurnan on Tue Feb 09, 2010 10:31 pm
The "lever" that Fordman speaks of is built onto the door lock itself. You can get a set of all 3 cylinder, (which would include the new ignition switch cylinder you also need) from NPD or DC for about $30.00.
JMcTurnan
Re: Door Locks
Post by JMcTurnan »
Would that lever also cause it to be hard to turn?
basketcase0302
Re: Door Locks
Yes, my P.S. had the same symptom as you describe. I got lucky enough to work some PB blaster into it and free it up a few days ago. You really should pull the door panel off before you buy anything though. :2cents:
Re: Door Locks
i don't think you can buy the little level new or reproduced. if its hard to turn that tells me either worn out key. or dirty mechanism someplace. probably the door latch. since it is the part that is being pushed on by the lever to open the lock on the latch.
so if the lock turns hard the lever is probably still there and working. it is either a bound up rod. doubtful. or a dirty latch or even dirt in the lock. just take them off and clean them up.
JMcTurnan
Re: Door Locks
Post by JMcTurnan »
Ok thanks, if it warms up that will be a weekend project. I cant buy what fordman? The level? Do you mean lever? So I cant buy a lock cylinder with the lever? Please explain
1971ford
Re: Door Locks
Post by 1971ford »
I'm confused... So the original question is that if you are in your truck, you open the door to get out, you push the lock down, you close the door, the lock pops up again therefore not locked... correct? Then it is determined that this is how it should be, so you don't lock your keys inside? Now were trying to figure out a way to "fix it"?
-Ryan
Re: Door Locks
sorry lever not level. i guess my mind may have been on a level or something. i have a 4 ft level i am thinking of putting on ebay. maybe that is what is on my mind.
JMcTurnan
Re: Door Locks
Post by JMcTurnan »
1971ford wrote:I'm confused... So the original question is that if you are in your truck, you open the door to get out, you push the lock down, you close the door, the lock pops up again therefore not locked... correct? Then it is determined that this is how it should be, so you don't lock your keys inside? Now were trying to figure out a way to "fix it"?
I was wondering if it was suppose to do that, then I asked a question about my lock cylinder because My driver side door wont lock from the outside. So were trying to guess what the problem is.
JMcTurnan
Re: Door Locks
Post by JMcTurnan »
So fordman, the lever is on the lock cylinder itself right? And I can just replace those to fix my driver side door?
