Door panels
OldRedFord
Door panels
Post by OldRedFord »
Those of you with steel door panels...
Have you replaced the screws with stainless ones? If so what size?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
91Bear
Re: Door panels
Post by 91Bear »
I think NPR sells a kit for those.
tanusfarms
Re: Door panels
Post by tanusfarms »
I haven't replaced them but I'll pull one out and take it in to work tonight. See if I can find it in stainless. If I can I' let you know in the morning. I'm doing a overnight shift in our electrical department tonight, Oh joy!
Greg
Custom Built and modified F250 highboy, custom dump box, Warn model 8274 winch mounted on the 335 lbs front bumper
Image Image
ForingaMex
Re: Door panels
Post by ForingaMex »
I have replaced mine with Stainless but I don't remember what size they were. It's been several years. Sorry
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
fordamericana
Re: Door panels
Post by fordamericana »
If i recall correctly, I beleive they were #8's I bought a box of ss screws at the hardware store, saved a boat load of money, and still have a bunch of them left over... I even used some to put the scuff plates in, and on the instrument cluster...
I likes My FE I does...
nmu91
Re: Door panels
Post by nmu91 »
I have a 71 with the Explorer package. The door panels are vinyl and I was wondering if I would be able to replace them with the steel panels?
Thanks for your help.
67MercM100
Re: Door panels
Post by 67MercM100 »
I used #10 3/4 inch oval head for mine. I'd gotten an assortment set from Auto Zone. Had to go check to see for sure - by looking to see which compartment was empty. I also just tried a #10 1 inch and it worked too.
garner67
Re: Door panels
Post by garner67 »
I used stainless bolts on my metal door panel.
I had a bunch of 1/4" x 20 j-nuts laying around, so I used those on the door. Then, I purchased stainless 1/4" x 20 x 3/4" (length) oval head phillips bolts and stainless 5/16 finish washers.
Here's a pic for ya.
71 F100
Mike
JMcTurnan
Re: Door panels
Post by JMcTurnan »
garner67 wrote:I used stainless bolts on my metal door panel.
[ Image ]
That is a dang good looking door!
