F600 cluster
- 1982 flareside
F600 cluster
My truck has a 1970 cluster. I was wondering if i need a 1970 f600 cluster or rewire? How hard is it to put in.
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
Re: F600 cluster
the F600 trucks were built in a different time period than our trucks. they didnt change the body style when our trucks were born. our body style wasnt started int he big trucks until later. and they were built up into the dentside era. 1975 or so.
the 70 F100/250 has two different plug connectors. one for gauges and the other for dummy lights. size is the difference on the two different plugs. the F600 gauges used a 67-69 F100/250 plug connector on them. so when using a f600 cluster you want to get the plug with soem extra wiring to redo your 70 connector with. i hate to say it but you will probably have to cut your harness and rewire it to install the F600 cluster into a 70 or newer truck.
- SoCalExile
Re: F600 cluster
Look at this thread for more info:
http://www.fordification.com/forum/view ... =8&t=38063
The good thing is that (at least on mine) the wires for both your truck and the F600 panel use the same color-code, with the exception of the purple one. It helps to get a F600 panel with the complete harness and connector.
