windshield washer ?
jpattt24
windshield washer ?
Post by jpattt24 »
what makes the windshield washer work in a 67 f100. does the water bag have a 12 volt pump or a foot pedal on it ? and if so how do you activate it. my 67 has no signs of any windshield washer parts. under the hood or inside the truck ? and no signs of a emergency flasher switch ?
67 351w roller cam gt 40 heads T-5 5 speed. ford rims 7.5 wide 275x60x15 tires http://s766.photobucket.com/albums/xx308/jpattt24/
Re: windshield washer ?
the flasher switch should be in the glove box. the washer does have a motor for it. it is seperate from the bag
jpattt24
Post by jpattt24 »
thanks, how do you activate the washer from inside the truck ?
from the wiper switch. just push it.
70_F100
Post by 70_F100 »
I thought the 67 had a foot pump, but I could be wrong...
jpattt24
Post by jpattt24 »
i checked mine you have to pull it. mr mustang has the fomoco washer bag with lines and t"s for $35.00 just need to find info on the pump for it. i have a bronco intermitten wiper setup i want to install i hope i can get the washer to work with it.
on pg 125 at the lower bottom right corner of the page. 47-4077 diagram number 13 is the pump. http://www.lmctruck.com/icatalog/fb/t.aspx?Page=124
