What is the carb throttle solenoid connection for?
sargentrs
Post by sargentrs »
'70 sport custom. 302, 3 on the tree, Ford 3.03 tranny, autolite 2100 carb. Just out tinkering with the old girl and noticed a wire I forgotten about. Diagram says it's the carb throttle solenoid connection. Green wire, fattest in the 4 wire harness coming from the firewall to the engine. Never have had it hooked up but was just curious so thought I'd ask. What's it for? Is it hot all the time or just when the ignition's on? Thanks in advance! Randy
70_F100
Re: What is the carb throttle solenoid connection for?
Post by 70_F100 »
Some of the early 70's model vehicles had curb idle speeds that were so high (to meet emissions standards) that when the engine was turned off, they continued to run (dieseling).
In order to correct this problem, while still meeting EPA standards, a solenoid was used as the idle stop when the engine was running. When the engine was turned off, the solenoid would retract, allowing the throttle plates to close. This prevented the engine from getting any air (and likewise, fuel) when the ignition was turned off.
Some manufacturers also used the same concept on vehicles with air conditioning to open the throttle slightly more when the compressor was on.
The wire should only have power when the ignition switch is on.
sargentrs
Post by sargentrs »
Great explanation! Thanks!
sargentrs
Post by sargentrs »
Must've been bad. Unhooked it and plugged the vacuum port and she runs a LOT smoother! Thanks!
Dragon
Post by Dragon »
I use that wire to run my electric choke.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away. :)
My Gallery
Spark test
sargentrs
Post by sargentrs »
Dragon wrote:I use that wire to run my electric choke.
Glad you mentioned that! My choke doesn't work and I thought about hooking up a new one with that connection. Thanks!
