Run stock gauges and a rally pack?
- fordamericana
Anyone try running both the factory oil and water temp gauges and an aftermarket three gauge cluster? I kinda like seeing the temp and the actual pounds of pressure, but I just rewired the whole truck and would like to run the factory gauges too...
I likes My FE I does...
Re: Run stock gauges and a rally pack?
It would be pretty easy to use a second set of sending units to power the second set of gauges. Just remove the sending unit, screw a T into the hole, and then put a sending unit in each side of the T, with one wired to the stock gauges and the other to the add-on gauges.
That would work for the oil pressure anyway. AFAIK the aftermarket mechanical water temperature gauge has a long sensor that probably wouldn't screw into a T, so you'd have to find a different place on your engine to install the second temp sensor or a non-standard T that would accept it.
- 70_F100
For the second temp sensor, you could screw it into the thermostat housing.
It wouldn't give you an accurate reading until the thermostat opened, but after the engine is warmed up, it should be VERY close!!
That's not an oil leak
- fordamericana
Hmm, sounds plausible. Suppose the best way is to play with it and see what I make of it...
