sterring wheel
- jimmy828
sterring wheel
has anyone used a Grant steering wheel if so was any modification involved?
- floyd67
Re: sterring wheel
buy the proper adapter and it bolts right on
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
2013 f-150 DD
- trukcrazy
Re: sterring wheel
Get the adapter for your year vehicle and it works good. I have used the same Grant wheel in 4 different trucks now.floyd67 wrote:buy the proper adapter and it bolts right on
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
- Mancar1
Re: sterring wheel
Nice wheel.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- jimmy828
Re: sterring wheel
nice wheel you have there.I was looking at foam grip wheel but i am concerned if a foam grip will be compatible to my manual steering.I know it will tale a little more force to turn wheel.Just thinking that the foam might not last.
Re: sterring wheel
the p o of my truck put one on.i looked nice but with manual steering i had to put the stock one back on.im to old to work that hard to turn my truck
Re: sterring wheel
how hard is it to put new wood and rivets in the wheels made like that. forming the wood is the easy part. but where woul dyou get those brass rivets and how would you put them back on?
- thorn1968
Re: sterring wheel
My cousin used to do custom wooden gun stalks, I wonder if it's similar?
Found this while searching...http://www.secondchancegarage.com/public/93.cfm
- trukcrazy
Re: sterring wheel
I used this same wheel in my 67 F100 with manual steering and had no trouble. Even parallel parking and 3 point turnarounds were doable. The thing about the real wood wheels is they don't get hot in the summer and they don't get cold in the winter. Good luck.jimmy828 wrote:nice wheel you have there.I was looking at foam grip wheel but i am concerned if a foam grip will be compatible to my manual steering.I know it will tale a little more force to turn wheel.Just thinking that the foam might not last.
John, #424
- Mancar1
Re: sterring wheel
I tried one on my 65 years back with manual steering. A few days later I changed back to the big old stock wheel. Man that 65 was a bear with the smaller wheel.jimmy828 wrote:nice wheel you have there.I was looking at foam grip wheel but i am concerned if a foam grip will be compatible to my manual steering.I know it will tale a little more force to turn wheel.Just thinking that the foam might not last.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- poonamt93
Re: sterring wheel
Steering Wheels are good!!
I use a Logitech Formula Force GP, but the MOMO, Driving Force Pro and G25 are all good wheels as well.
Re: sterring wheel
wheels are the hardest part of my build steering and the 4 rolling ones.
