Vintage diesel for 1959 Ford truck?
No tech discussion, please
petersen2020
Post by petersen2020 »
I have a 59 ford truck id like to put a diesel in. People tell me the 5.9 cummins would be cool in there, and i know it would, but i would like to do something more period correct. Does anyone know of an engine around 5 to 7 liters from that era,mid 50s to mid 70s? Caterpillar, cummins, perkins, international, even tractor engines, does anyone know of anything?
side mirror
71rangerxlt-fred
Re: Vintage diesel for 1959 Ford truck?
Post by 71rangerxlt-fred »
The 5.9 cummins has been around a long time. Before Dodge got a hold of it they caled it a "b" series diesel, I think they were around in the 60's but not sure. A 4 cyl. would work well in the f-100. The chevy step vans used them known as the 4BT engine. Not a power house but good economy. Perkins diesels would be a viable choice also, availiable in lots of combines. Would require some work to the governor because you want speed limiting type instead of load type.
Morgan
71 f100 xlt black and white 390 c6
71 f100 xlt 2 tone green 302 c4
79 f250 4x4 460 4 speed
79 f250 4x4 460 auto snow plow special
element7878
Post by element7878 »
1967 ford f100 Shortbed
Ford 360,edelbrock intake,holly 4bbl 600,rv cam
San Antonio, Texas
basketcase0302
Post by basketcase0302 »
http://www.doormirrors.ca/
I believe there's a place for vendors ads here somewhere? :yt:
Good luck with your diesel conversion. :thup:
Fordboyrod
Post by Fordboyrod »
I heard a rumor that the diesel engine from a Ford 6000 tractor will bolt up where the inline six gas engine came out of.
fastEdsel
Post by fastEdsel »
When I was 7, in 1957, my Dad and his brother ordered and bought 2 brand new F100 Ford pickups. Both 223-6cyl, automatics, and stepside boxes, and Custom Cabs. They should have ordered the 292-auto, the 223 six was almost a disaster in these trucks that were actually named "Ford-O-Matics." Anyway I remember Dad looking over the order paper and said that there was a diesel option available for the '57. It was an English diesel, most likely built for the farm tractor division Ford had in England. I am also real certain that it was a Perkins. If you could bolt a 354 Perkins turbo diesel in your truck it could be a tire shredder. They were a real popular combine engine used on this continent and installed on Massey Ferguson 750, 760, 850 and 860 model machines. I had one in a 750 and it was a real great engine and real easy on fuel and it was turbocharged. Do your research then when you get things lined up, find a "combine wrecking yard", there are some huge yards here in Canada, and that is where you will find a 354 if it is the right engine that was used in that vintage of truck. Most likely that engine would have been a 4 cylinder but you would have to find that out also in your research. Happy hunting!
adrianspeeder
Post by adrianspeeder »
Old screamin' Detroit would be fun.
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
fastEdsel
Post by fastEdsel »
Yes that would be different, a "green leaker in a old Ford sleeper!" 8) :fr:
Whateverman
Post by Whateverman »
I realize that its a GM product,but how about an old Jimmy 2 stroke diesel?
http://www.youtube.com/watch?v=E0o1o5W_f6o
averagef250
Post by averagef250 »
Screamin Detroit = 2 stroke Jimmy
The only engine which driving one is like having your head inside the engine.
wyowill
Post by wyowill »
Probably the most correct for the era would be a Detriot Diesel 53 series. 4-53 or 6v-53 for a mid size truck or if you have a big truck there were a lot of 6-71's used . An uncle of mine had a 1959 ( F-450-500?)stake bed ranch truck with a 4-53 and straight pipe. Cattle were hearing impared by the time they were to the sale barn. Were also a lot of Perkins used, Willys even had a Perkins option for the CJ-5. Will
AlleyCat
Post by AlleyCat »
adrianspeeder wrote:Old screamin' Detroit would be fun.
Adrianspeeder
For about a half hour. :) Seriously Adrian have you ever sat behind a Dumptroit for 8 hours or so? :) The first big wrecker I drove had a 6-71N. I'd get a run from Pittsburgh to say Morgantown, WV or Harrisburg, PA then go home and try to fall asleep with that ringing in my ears. :lol:
Clay
george worley
Post by george worley »
a couple of years ago a guy would come to our weekly cruise with a 52 Chevy pickup with a Detroit Diesel 2-stroke in it.It was really loud and put out a lot of fumes. :lol:
averagef250
Detroits have some fans out there and the engines did have some high points like being able to run about the same with significant internal damage, not terribly hard to work on and they would certainly never rust with all they leak. The best 2 stroke Detroits were the big ones. They still shine in moderate load, rough atmosphere applications like marine and sawmill/shredding applications. Mostly because there's no other 500HP 1800 RPM engine you can buy for less than scrap price.
