I'd like to get a bench vise. I'm interested in recommendations as far as size of the vise and type of vise for general automotive repair type work. For example, I've seen there are "machinist" vises that in addition to the regular jaws, have a set of jaws beneath for holding pipe. I don't know if that would prove useful to have or not.
Any suggestions are welcome.
Bench Vise Recommendations
- flyboy2610
Re: Bench Vise Recommendations
http://underbid.com/merchant/garagetoys ... l?ref=base
This is the one I have. It is very well made, and sturdy. Be sure to bolt it down to your workbench. The pipe vise is something I haven't used a great deal, but it sure was useful when I needed it!
You could probably find it for less than this, though.
- DMiller
Make sure your workbench is solid and stays put also.
Nothing better than an old truck...
71 F250 Custom
92 Chevy Z71
71 F250 Custom
92 Chevy Z71
- 1971fordcustom
This is mine! its from 1939,
Go find a old one from the 40s or 50s! Last 4 ever
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1960 Ford F-750 FireTruck
1960 Gmc 6000 FireTruck
1962 IH R-185 Firetruck
1959 Ford Custom 300
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
- BRUTUS_T_HOG
i say get a big machinist vise. the rotating function really helps on some jobs.
i work full time as a mechanic and use both types and i like the rotating one a lot more.
ASE Certified Technician
- Mancar1
The big one on the right is a old Wilton Cadet it opens to 8".Made in Chicago, USA. The one on the left was my Uncle's, (He is gone now). It opens to 5 1/2", and is a AC #460 with the inside pipe clamp. The little clamp on one opens to 3 1/2", and is a Black and Decker. Good for small on site clamping. My favorite is the Wilton Cadet, it is pretty much bullet proof, and USA made.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- BobbyFord
What you want is a U.S. made vise, not any over-seas made crap.
Check out Yost vises: http://www.yostvises.com/products.htm
- robroy
Bobby, those look really nice, and are actually a lot less expensive than I figured they'd be! $260 doesn't seem like too much for a vise that could last for generations. (I need a vise too, which is why I'm so interested!)
Robroy
Robroy
- averagef250
The primary vise in my shop is Yost, same one they show on thier website front page, but mine came off a decommed 1960's Frigate.
Really good vise. It's taken plenty of abuse and use and actually does look like brand new. The original hardened jaws are still so sharp that they're covered with aluminum most of the time to keep from marring work.
