OK so this is what I am looking at ordering. It is the only kit I could find that I liked with a vacuum gauge.
http://www.summitracing.com/parts/VDO-600-93516/
Brand VDO Gauges
Manufacturer's Part Number 600-93516
Part Type Gauge Kits, Analog
Product Line VDO Series 1 Analog Gauge Sets
Summit Racing Part Number VDO-600-93516
Gauge Style VDO Series 1
Oil Pressure Gauge Included Yes
Water Temperature Gauge Included Yes
Voltage Gauge Included Yes
Ammeter Gauge Included No
Speedometer Gauge Included Yes
Tachometer Gauge Included Yes
Fuel Level Gauge Included Yes
Fuel Pressure Gauge Included No
Oil Temperature Gauge Included No
Boost Gauge Included No
Pyrometer Gauge Included No
Transmission Temperature Gauge Included No
Brake Bias Gauge Included No
Clock Included No
Gauge Face Color Black
Gauge Number Color White
Bezel Color Chrome
Pointer Color White
Gauge Series Analog
Mounting Bracket Included Yes
Warning Lights Included No
Quantity Sold as a kit.
Notes Kit includes fuel sender, temperature sender, oil pressure sender, Ford/AMC push-in style speedometer sender, and all necessary connectors.
A break down of each of the gauges starting with the Vacuum Gauge (Sold Separately)
http://www.summitracing.com/parts/VDO-150302/
Brand VDO Gauges
Manufacturer's Part Number 150302
Part Type Gauges, Analog
Product Line VDO Series 1 Analog Gauges
Summit Racing Part Number VDO-150302
Sending Unit Mechanical
Gauge Type Vacuum
Gauge Range 0-30 in. Hg
Gauge Size (in) 2 1/16 in. diameter
Gauge Size (mm) 52.40mm diameter
Sweep Full sweep
Pointer Color White
Bezel Color Chrome
Liquid-Filled No
OEM Replacement No
Sending Unit Included Yes
Quantity Sold individually.
Notes Includes adapter, and T-connection.
Gauge Series Analog
Voltmeter
http://www.summitracing.com/parts/VDO-332341/?rtype=10
Brand VDO Gauges
Manufacturer's Part Number 332341
Summit Racing Part Number VDO-332341
Sending Unit Electrical
Gauge Type Voltmeter
Gauge Range 8-16 V
Sweep 90 degree sweep
Pointer Color White
Bezel Color Chrome
Liquid-Filled No
OEM Replacement No
Sending Unit Included No
Gauge Series Analog
Oil Pressure
http://www.summitracing.com/parts/VDO-350303/?rtype=10
Brand VDO Gauges
Manufacturer's Part Number 350303
Summit Racing Part Number VDO-350303
Gauge Type Oil pressure
Gauge Range 0-80 psi
Pointer Color White
Bezel Color Chrome
Liquid-Filled No
OEM Replacement No
Gauge Series Analog
Fuel Gauge
http://www.summitracing.com/parts/VDO-301303/?rtype=10
Brand VDO Gauges
Manufacturer's Part Number 301303
Summit Racing Part Number VDO-301303
Gauge Type Fuel level
Gauge Range Empty-full
Sender Ohm Range 0 ohms empty, 90 ohms full
Pointer Color White
Bezel Color Chrome
Liquid-Filled No
OEM Replacement No
Gauge Series Analog
Water Temp
http://www.summitracing.com/parts/VDO-310304/?rtype=10
Brand VDO Gauges
Manufacturer's Part Number 310304
Summit Racing Part Number VDO-310304
Gauge Type Water temperature
Gauge Range 100-250 degrees F
Pointer Color White
Bezel Color Chrome
Liquid-Filled No
OEM Replacement No
Gauge Series Analog
Tachometer
http://www.summitracing.com/parts/VDO-333355/?rtype=10
Brand VDO Gauges
Manufacturer's Part Number 333355
Part Type Tachometer Gauges
Product Line VDO Series 1 Tachometers
Summit Racing Part Number VDO-333355
Tachometer Usage Standard
Gauge Series Analog
Gauge Range 0-7,000 rpm
Gauge Size (in) 3 3/8 in. diameter
Gauge Size (mm) 85.00mm diameter
Sweep Full sweep
Tachometer Installation In-dash
Pointer Color White
Bezel Color Chrome
Rev Limiter No
Memory Recall No
Playback No
OEM Replacement No
Gauge Type Tachometer
Speedometer
http://www.summitracing.com/parts/VDO-437353/?rtype=10
Brand VDO Gauges
Manufacturer's Part Number 437353
Part Type Speedometer Gauges
Product Line VDO Series 1 Speedometers
Summit Racing Part Number VDO-437353
Gauge Series Analog
Gauge Range 0-120 mph
Sweep Full sweep
Tripometer Yes
Tripometer Display Digital
Pointer Color White
Bezel Color Chrome
Gauge Type Speedometer
Fuel Sending Unit
http://www.summitracing.com/parts/VDO-226008/?rtype=10
Brand VDO Gauges
Manufacturer's Part Number 226008
Part Type Gauge Sending Units
Product Line VDO Fuel Tank Senders
Summit Racing Part Number VDO-226008
Sweep 180 degree sweep
Thread Adapter Fittings Included No
VDO fuel level senders are constructed from high-quality materials for reliability and are gold iridited for long-lasting protection. They are adjustable for tanks from 6 in. to 23 in. deep and for left or right hand float mounts. They will fit several types of gauges, including most aftermarket and OEM gauges, and will save you the time and aggravation of trying to custom-build your own sender.
I need to read back over Robroy's post but I think the fuel Ohms is off, I would probably have to get the above sending unit for these to work. Has anyone used this brand before? Any reviews I guess you could say. This kit is suppose to be adaptable to Ford Transmissions, but again I am no expert
