smokey3215 wrote:i just found a cool site for everyone who likes to make tools its homemadetools.net
That's the big trans like a c6 but with a overdrive? Those trans can get heavy...ultraranger wrote:I made this transmission holding fixture, last weekend, to use while tearing down/rebuilding the 4R70W transmission that will be going in my '69 F100 Ranger.
http://www.fordification.com/forum/view ... 92#p614152
No. The E4OD/4R100 overdrive transmissions were developed from the older C-6's.timmytim wrote:That's the big trans like a c6 but with a overdrive? Those trans can get heavy...ultraranger wrote:I made this transmission holding fixture, last weekend, to use while tearing down/rebuilding the 4R70W transmission that will be going in my '69 F100 Ranger.
Hey thanks for the info....This is off subject but its electronic so you having to carry the computer from donor car over to ure pickup? I have a straight 6 that one day plan to add the aod. it should be easy swap cause ford small blocks have same bolt pattern as 240 straight six. i just got to find the flywheel and converter that will work with set up.[/quote]timmytim wrote:No. The E4OD/4R100 overdrive transmissions were developed from the older C-6's.
The 4R70W evolved from the AODE. The AODE evolved from the AOD and the AOD was devolped from the C-4/FMX transmissions.
