From 2wd to 4wd
mybros71
Re: From 2wd to 4wd
Post by mybros71 »
Its a major job. Most guys on here would advise to find a 4wd pickup and start there. That being said...If you know what you are doing, you could fab it up nice. All it takes is time and money, lots of money.
And time.
Tony
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
Ripsnorter
Re: From 2wd to 4wd
Post by Ripsnorter »
I have a '63 F250 I want to convert to a 4WD. I had just planned on taking a donor truck, in my case a 1980 F250 4x4, and swapping everything over. I've even contemplated just taking the body off the frame and swapping it onto the '80 frame.
HIO Silver
Re: From 2wd to 4wd
Post by HIO Silver »
ericevenski wrote:O have a 1970 2wd how hard is it going to be to make it 4wd? How much fab work if any or can I just change everything out without modifying anything?
Doable. This article covers the conversion of a 2wd 79 Dent to 4wd but the principles are the same. http://www.4wheeloffroad.com/project_tr ... index.html
It's easier to start with a 4x4 or find a donor to swap, mix, and match.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
