Make your own: Wheel bearing race installers
72BahamaBlue
Post by 72BahamaBlue »
Many years ago a mechanic taught me this;
After removing the wheel-bearing races, sand the outer circumference on a disc sander until it's a slip fit into the hub.
These took about 20 rotations with gentle pressure against the sander until it would slip into the hub with a little play.
Use the thicker end of the ring for hammering, some easy tapping and drive them in. Works really well!
sargentrs
Re: Make your own: Wheel bearing race installers
Post by sargentrs »
Great idea! Thanks for posting.
tbone6
Post by tbone6 »
:thup: Thanks, good tip!
t6
1972 F100
ToughOldFord
Post by ToughOldFord »
Great tip! :thup:
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
tac
Post by tac »
Be sure and sand it. When I was young and dumb I did this and it was really hard to get out.
1972hiboy
Post by 1972hiboy »
this is a great idea. I use a wheel bearing race to drive in the big 9864s seals works like a champ!
Rich
Dont eat yellow snow.....
HIO Silver
Post by HIO Silver »
No need to grind.... use a cut-off wheel and cut a slot through one side of the race.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
Madman
Post by Madman »
HIO Silver wrote:No need to grind.... use a cut-off wheel and cut a slot through one side of the race.
That's a damned good point there HIO!!!! I personally use a brass drift 90% of the time, but will try this for those times where the final amount to drive it seems a bear to get the drift on the darn race!
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
