my 72 long bed bump
my 72 long bed bump
My plans were a cv frontsuspenion but with my motor beening screwed the money will go to the motor so no cv right now.
Revised plan rebuild motor sleeve if it needs it and go with beams from a 73-79 for dics
low and ugly 72 longbed with a 360 converted to a 401 with performer intake and a 750 double pumper carb 260 cam and headers with a c6 auto and stock 9 inch lowered about 5.5 /7.
Build thread http://www.fordification.com/forum/view ... 22&t=79488
Re: my 72 long bed bump
Ok the motor here's the pics
Well it seems that when the motor was rebuilt it was made into a long rod 390.
When I was tearing it apart I found a circlip in the oil pan from number 8.
Well I took the block and heads in to the machineshop yesterday and I'll get them back this coming month
The block will have to be sleeved which I knew to begin with but it will be bored 60 over because of gouged in one of the bores
Ok it's been a bit since I updated anything bout the truck so here goes
the block has been bored to 60 over found a 390 block and crank and rods for 150. My 360 now is a 401. The stock d2 heasds were wore out so I found a set of c1ae. Then my neighbor has a friend that drives a bump that has a 67-69 front clip I'm trying to get.
- hfdco4
Funny how you can look far and wide for parts and one day they seem to appear out of nowhere. At least you are making progress.
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
1970 F250 4x4
Funny ain't it but yeah it's going to be be a slow gains till it's roadworthy but oh well I knew that when I started it
- Mancar1
Yes it takes a while, but the end result will be worth it
Keep on Trucking....John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
I'm too hard headed to give up on it and I love these bodystlye trucks anyway. yeah it's going to be fun.
I'll get some pics as soon as something changes.
Forgot to post this but the heads that I took in were c8ae instead of c1ae but they're wore out as well but they will have cj valves instead of stock and my d2teaa's I'm gonna try porting.Them it's a little closer to running.
I might have figured out how to fix the pos lowering job useing 4wd spring pockets and 3 inch springs and converting to discs from a dent.
As soon as I can post pics I'll show the "new" grill I just picked up
Well what the truck that the front clip came from must have enjoyed playing asphalt . when I pulled it apart the back of the fenders where covered in it ... no wonder it was so heavy
I put the fenders and passenger side inner fender on as well as the grill man what a difference
