is something inside this brass nozzle bad? or is it the canister?
thank you. i had no idea what the parts were called in this torch. i located the orifice which is right behind the tip i think. and yes it is clogged. i am going to soak it in gasoline and see what happens. don't have any fine wire. i wonder if someone sells a orifice cleaning kit or a tip cleaning kit... if i can't clean this orifice out i'll attempt to find a replacement by calling bernzomatic.Nitekruizer wrote:Looks like a cool old torch. I doubt the cylinder (tank) is the issue. I would check to make sure that the little orifice isn't in backwards or that it's not missing. I think replacement orifices are still available if it is missing.
