Parts washer upgrade
I have made an amazing improvement on my Harbor Freight parts washer. I bought a closeout water heater element at Home Depot for 5.00. It is rated at 1500 watts and operates on 110 volts. I drilled a hole in the side of the tank and installed the heater element with its O-ring and locknut on the inside. It absolutely doesn't leak and the results are amazing! I use a water based heavy duty degreaser from Home Depot. It was only about 10.00 for a gallon. This combination of heat and degreaser will take the paint off of oil pans easily. It gets so hot that after an hour I have to turn it off because the steam is so great. It takes about an hour to heat up to full temp.
1967 F-100 4x4 custom cab.
Re: Parts washer upgrade
Wait, it will take the paint off?! as in a home made blaster alternative?
1953 F100 (Waitint for attention)
1969 F100 LWB w/ 72 grille (Daily driver & work truck)
1969 F100 LWB Parts truck
1971 F100 SSWB 4x4 (Current Project)
2016 Jeep Wrangler Unlimited Sport (Actually the wife's)
- KRob
Yeah, please confirm that it takes paint off and so forth.
Can you give us a link for the degreaser you use.
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
I used Purple Power.
- 48prerunner
Do you have to wear rubber gloves?
I have switched from a solvent based cleaner to water based SUPER CLEAN (about $9 gal. Walmart) because it is much safer, a reasonable price, and works as well in the parts tank or as a spray-on. It will take paint off as well so be careful.
I recommend using a 100% biodiesel. It cleans good and is environment-friendly.
- basketcase0302
I kept a 5 gallon bucket of regular diesel around for some 10 years using it as parts cleaner-works well."geradr4"]I recommend using a 100% biodiesel. It cleans good and is environment-friendly.
