Coil springs
- timmytim
Coil springs
What is the proper way to remove front coil springs at a pull a part...I normally use a spring compressor tool or a floor jack to slowly let it down. Pull a part don't let me bring in jacks.
buy'em dirty sale'em clean
get more money for the same
machine.....
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
Re: Coil springs
Loop a chain through it so it doesn't get away from you. ? ?
- timmytim
Re: Coil springs
That's a good idea bud
machine.....
- basketcase0302
Re: Coil springs
Like CEP said above, I can remember using ratchet straps years ago for safety, (can't remember if I ever tried compressing them using ratchet straps or not)?
Re: Coil springs
Any chance you might find a scissor jack in one of the other vehicles? I dropped the front springs out of a Firebird once using a jack from a Eagle Talon and a bicycle cable with its padlock. The chain idea is better but I used what I had in the trunk. Do they want to rent you a jack? My days of dropping a transmission onto my chest are long past. I know I have seen a cherry picker pulling a motor at one of the local you-pull-it places but that was a while ago.
No Brain - No Pain
71 F250 Sport Custom Camper Special
71 Ranchero Squire
70 Ranchero GT (Red w/351C 4V
70 Ranchero GT (Black w/302+)
03 Kawasaki Vulcan 750
74 Kawasaki H2 750 (Widowmaker)
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
71 Ranchero Squire
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
- timmytim
Re: Coil springs
I've been lucky and found couple trans removed and laying on ground under car. I hope they didn't have run to take a bathroom break....
machine.....
Re: Coil springs
The pick a part I frequent leaves vehicles up on home-made stands of steel wheels welded together so everything is extended. I just knocked bottom shock bolts out and then unbolt the top. Then deal with the long bolt thru the i-beam. Be sure to keep the perch on top of i-beam. They are hard to locate separately.
68 Ranger. 302 Clevor w/ 3 on tree, soon to have front disc brakes.
