instrument cluster
1970f100x
instrument cluster
Post by 1970f100x »
Ok, so I have a 1970 f100, and I went for a drive last night. When i turned on my lights, the instrument cluster's lights are very dim, but the turn signal light is strong. Uhm, how should I go about fixing this problem? Buy a new cluster, or is there an easy way to replace the lights?
FLATBEDFORD
Re: instrument cluster
Post by FLATBEDFORD »
Maybe you tried this already. The headlight switch is also a dimmer control for the cluster lights. With the headlights on, rotate the knob to make adjust the intensity of the lights. Turn it all the way and the dome light should turn on. I have no idea which way to turn it, I don't remember stuff like that. :D The trn signal indicators are independent from the other other cluster lights. I hope I helped you out.
My Photo Gallery
1970f100x
Post by 1970f100x »
FLATBEDFORD wrote:Maybe you tried this already. The headlight switch is also a dimmer control for the cluster lights. With the headlights on, rotate the knob to make adjust the intensity of the lights. Turn it all the way and the dome light should turn on. I have no idea which way to turn it, I don't remember stuff like that. :D The trn signal indicators are independent from the other other cluster lights. I hope I helped you out.
Oh my god, thank you, thats cool. This is my first car/truck.
Durockrolly
Post by Durockrolly »
Welcome to the world of modern transportation! Before you're done you will have learned a ton of little tricks like this to keep you rolling. Keep it fun!
Fernando.
FLATBEDFORD
Durockrolly wrote: Welcome to the world of modern transportation! Before you're done you will have learned a ton of little tricks like this to keep you rolling. Keep it fun!
Fernando.
Actually, welcome to the world of NON modern transportation. :D
My Photo Gallery
