weak blower motor
- austin
weak blower motor
hello everyone my blower motor seems to spin very slow i assuming thats the way they came so anyway is there a way to fix maybe a new one?
Re: weak blower motor
Heater blower motor, correct?
Most came as a two-speed...does your switch have a high and low setting? And if so, do they both work? There's a resistor mounted on the back of the heater box that controls the speed, it's possible yours needs replaced. It's also very possible you simply have 40 years worth of dust and garbage inside the blower, and so by removing the motor, blowing it out and giving it a couple squirts of oil, you might remedy the situation.
- austin
it works on the two speeds so i will clean it out thanks for the idea
Dont get any oil inside the motor. just on the shaft near the end bushings. most electrtic mototrs have a bushing or bearings at each end shaft to keep the shaft spinning freely on an even basis. oil inside of the housing could short out the motor or make it collect dirt hair and all kind of stuff. then it will get even worse as far as dirt buildup.
- rjewkes
is the resistor on the back that two side ways and side by side spades?
i left mine unhooked and only have one speed. high only works the slower speed.
yes that is the resistor back there. careful unplugging and plugging them in. they break pretty easily.
- rjewkes
so without that it won't work correctly hahaha bet i plug it in and i get both speeds.
- austin
well i feel stupid my blower motor was blowing just fine it just wasnt defrosting my winshiled very good cause the gasket in the flapper thing is gone so i just duct tapped the holes around the box so know all of it goes to defrost
this is temopray i will fix it right
- 70_F100
Fordman, we might even know some of the same ones!!
That's not an oil leak
