Holy Cow!! Check this out! Convertible Crew Cab in SoCal!
Online listings for vehicles only. No parts listings please.
BobbyFord
Re: Holy Cow!! Check this out! Convertible Crew Cab in SoCal!
Post by BobbyFord »
I would slam that thing in the weeds.
70shortwide
Post by 70shortwide »
Calfdemon wrote:The one thing that I noticed which I am going to look into, is he put armrests on the rear doors. The way the rear doors are cut and put together internally, I am not sure how he was able to do that. I have the stock plastic squares that go around the door handle, but if I can get the armrests on there like he did, that might be a better option.
I doubt that there are internals in those doors. without the glass there isnt much need for anythin behind the door panel. however, I think the crew cabs did come with armrests in the rear? I thought I read somewhere that they were smaller and also used in econolines... mayybe Im thinking of the 67s... :?
Calfdemon
Post by Calfdemon »
No, the crew rear doors did not have armrests on them. They had a square plastic part that went around the door handle which worked as a pull... But they are not armrests. These are the same parts that were used from the Econoline vans and are no longer made. I have the stock pair from my crewcab and will probably use them.
I didn't think about the glass not being in those doors... You are right and that is how he got the armrests on the back doors. Good observations. Looks like I will just run the stock door pulls them. Its not as if I will ever ride in the backseat of my truck anyway. If someone wants an armrest, they can roll the window down! :lol:
-Rich
Current toys -
Former toys -
fbomb100
Post by fbomb100 »
Calfdemon wrote:No, the crew rear doors did not have armrests on them. They had a square plastic part that went around the door handle which worked as a pull... But they are not armrests. These are the same parts that were used from the Econoline vans and are no longer made. I have the stock pair from my crewcab and will probably use them.
is it the your worried about running the screw in to the glass?? and if so can't you just weld a stud on the door and use a nut to tighten the arm rest to the door?? now I have never seen a crew up close so I'm not see what you are .
jp2005
Post by jp2005 »
Thats crazy! haha
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
