I like the 89' era seats. they have the armrest, and are fairly modern. I need to put it in a 71' just like http://www.classictrucks.com/features/0 ... 100_truck/ but don't know if the seat will be the right width or if it uses different brackets? out of a 89' Ford, into a 71' Ford.
Thanks for the great site Keith,
Tyler
89' Seat?
- 68F250
- SmokeyBear
- turbocharged400sbc
re: 89' Seat?
same thing with my 86 bench, had to use a hammer to smak out the studs on the 68 brackets but bolted right up using the 86 seat and bolts...
i like it now...seatback is higher and interfears with my gunrack though....
all in all much better than sitting on a spring
1994 Olds 442 (425 cid-4 wheel drive-2 V6's) http://www.cardomain.com/id/94twinengine442 13.81 @ 98.2 MPH 1.9s 60's
68 F250 Camper Special 390FE/NP435/3.73D60
soon: 79 F350 disk brakes w/ 3.55 D60, pneumatic, 1750w AC inverter, Vector 1600w lightbar, 200A 3g alt, all a mobile gearhead needs
- Big D's 69
re: 89' Seat?
Just hope your a small guy cause with the tank behind the seat you might loose soem room.
