Did I Do Good?...Steering Column Qs...
Alright, so I'm going to be swapping in an automatic tranny when I swap engines this summer, so today I went to the junkyard to get an automatic column and shift linkage. There were no bumpsides with auto columns in the yard, but plenty of dentsides to be found, so I got what I could.
What I found was a 74 F-100 with manual steering and an automatic. The shifter/shift tube felt nice and tight when I worked the linkage (not sloppy going into Park, like most of the dentsides I've seen), so I grabbed this column.
Did I do OK? My truck is manual steering, as was this donor truck. I just want to make sure this column is going to work in my truck before I take it apart to rebuild and paint it? My truck is a 72 F-100, currently 3 on the tree.
Now, I have some questions:
-Are the rebuild parts for this column going to be the same as those for a bumpside column? Just by looking at it, it looks exactly like a bumpside column (except for the hazard switch).
-Anyone know a source for the detent layout panel (the clear plastic part with the shift pattern printed on it), and a new pointer for it?
-Also, a new grommet for the shifter? (where the selector goes into the column)
Thanks guys
Nick
P.S. Anyone know how to convert the wiring in this thing to bump spec?
Thanks guys
Nick
1972 F-100 Custom SWB
- rjewkes
red/black stripes to brake light switch
green/white stripes to LH front turn signal
white/orange stripes to emergency flasher
yellow/brown stripe (I could only find yellow/black stripe to LH rear turn signal)
white/blue stripe to RH front turn signal
blue to turn signal flasher
blue/red stripe to "PRNDL" lights
green to RH rear turn signal
yellow/blue to horn relay
73-77 Fseries column wired to 1972 Fseries.
White / Blue to Front Right Turn Signal & Indicator Light
Green / White to Front Left Turn Signal & Indicator Light
Black / Red to Stop light switch
Yellow/Black to Rear Left Turn Signal Light & Brake Light
Light Green to Rear Right Turn Signal Light& Brake Light
Blue to Turn Signal Flasher
White/red stripe is for the Hazard lights
Blue/Red stripe - Gear selector courtesy Light
Lg.Yellow/green dots --Horn this one was also the same color between the two colums.
*Note. Wiring code changes if cruise control is used.
now on my 77 colum with built in cruise control the wire from the column for the right rear brake/turn was dark green. other wise everything else matches.
fuelly.com
fuelly.com
- 67highboy
re: Did I Do Good?...Steering Column Qs...
That there is some good info rjewkes
John
John
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
Ben Franklin 1775
- rjewkes
yeah seems I always do an upgrade or rewire or install or have a problem and bam just after i fix it somebody has a similair problem.
fuelly.com
fuelly.com
- 67highboy
Sucks to always be the guinea pig don't it
John
John
Ben Franklin 1775
Ben Franklin 1775
- rjewkes
Actualy I don't mind.
fuelly.com
fuelly.com
Thanks rjewkes!
You have saved me some headaches!
Nick
Nick
- rjewkes
No problem.
fuelly.com
fuelly.com
- cathynkeith
hey rj do that for me, converting to gm style wiring, I'll give ya a kiss.
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
