67 Project Update 6/1/2023 (Multiple New Posts With Pictures)
JWW
Post by JWW »
I originally started in this forum...
http://www.fordification.com/forum/view ... hp?t=21026
but I decided to start posting here.
I finally got my truck into the garage. I was wanting to keep things as simple as possible. However, each time I remove a part, I notice something else. This old truck has some rust issues. I did buy a mig welder to do patch panels. I figure I will learn how, just practice, practice, practice...
So far I have removed the bed, hood, fenders, doors, and one inner fender. I don't get much time to work on her, but I try to at least a little each evening.
Well, I'll keep posting. Here are some pics.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
JWW
re: My 67 Project
Post by JWW »
More pics attached... :D
JWW
2004 F150 Crew Cab
ezernut9mm
re: My 67 Project
Post by ezernut9mm »
you're going to have one sweet ride when you are done! shorties rule!
gmcjimmy88
re: My 67 Project
Post by gmcjimmy88 »
That is a good looking truck and it is nice to know it has been in the family that long. Keep at it and you will enjoy the fruits of your labor, and it will be sweet.
[quote="MOST OF ALL, pray about it. If God doesn't want you to go, he will make it clear.[/quote]
1967 F-100 Longbed (project truck) For sale $1200 http://www.fordification.com/galleries/ ... ?album=710
http://www.fordification.com/galleries/ ... ?album=726
1990 Blazer (offroad toy) 7 in. lift, 37 in goodyear MTR's
2000 Ford Focus (DD/commuter car) ABOUT TO BECOME TARGET PRACTICE!
2005 GMC 2500HD Ext. Cab Longbed (Towrig for the blazer)
2006 Kaufman 20ft steel deck car hauler (The only way the Blazer sees the road)
Manny
re: My 67 Project
Post by Manny »
It looks to be in pretty good shape runs and drives and the core supports good awesome man :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
bigjake34452
re: My 67 Project
Post by bigjake34452 »
you're gonna hop up that six right? well if not, im always in the market for a six :thup:
JWW
Re: re: My 67 Project
Post by JWW »
bigjake34452 wrote:you're gonna hop up that six right? well if not, im always in the market for a six :thup:
I hope to get her cleaned up. I'll keep it stock. Who knows, I may beef her up someday.
JWW
2004 F150 Crew Cab
JWW
re: My 67 Project (I need some suggestions)
Post by JWW »
OK, I'm ready to either clean the engine, roll the cab onto it's back or work on the steering components. However, I don't know which to do first.
So, anyone with any suggestions would help. Do I fix the steering first? Clean the engine first(I'm not planning on pulling the engine)? or Do I roll the cab onto it's back? I have never done a project like this before so I don't want to go out of order.
What has worked best for you guys???
Thanks in advance.
JWW
2004 F150 Crew Cab
JWW
re: My 67 Project (Need some suggestions see next to last po
Post by JWW »
See post above. I'm up for any suggestions on the next step in my rebuild process.
JWW
2004 F150 Crew Cab
lightning_msd
Post by lightning_msd »
i would say for sure clean the engine first, then work on the cab and steering, i know this from personal experiences, when i painted something then cleaned something, i had to paint something again....
lightning_msd
but maybe roll back that cab so you can get at the trans too
JWW
Re: re: My 67 Project (Need some suggestions see next to las
Post by JWW »
lightning_msd wrote:but maybe roll back that cab so you can get at the trans too
That was what I kinda thought. I figure I can roll the cab back, and get the engine and trans in one wack. Plus I can roll the truck in and out of the garage for hosing off.
JWW
2004 F150 Crew Cab
layedout72
Post by layedout72 »
Take the steps to do it all at once, but manage your time on a section at a time. Taking the steering out will allow you to roll the cab back. By doing that....you can clean the engine/tranny. So my schedule of events would be, engine cleaning, body working, steering work. That way when you get the engine cleaned, the body back on, the steering in, it's all ready to drive again!
Whoaaanelly
re: My 67 Project (Need some suggestions)
Post by Whoaaanelly »
Yeah, I'd roll the cab back and out of the way, then buy a case of oven cleaner and spay it all down and let it soak for an hour and then pressure wash it all. Then you can inspect and replace the parts you need to replace, paint the front end, frame, and engine. Then you can work on the cab in between while it's rolled back to do the work (as needed) underneath, then paint the bottom and roll it back into place. Then you can work on the interior of the cab, the back, any wiring inside and start cleaning the front-end sheet metal parts to get them reinstalled.
It's a nice truck. Great trim package. I'd love to have the gutter stainless on mine!
The picture of you driving it was classic with the old lady watching. People must think we're nuts! I know my neighbors must have thought that of me when I first drove up in mine blowing smoke and all. Now I get compliments all the time. Have paitience and the reward is worth it!
Roger
____________
07 Ford Escape Limited (first new car ever)
78 F350 Flatbed (Dentside)
67 F100 Pickup (Bumpside)
65 Falcon 2-door Wagon
63 Falcon Ranchero
JWW
Re: re: My 67 Project (Need some suggestions)
Post by JWW »
Whoaaanelly wrote:Yeah, I'd roll the cab back and out of the way, then buy a case of oven cleaner and spay it all down and let it soak for an hour and then pressure wash it all. Then you can inspect and replace the parts you need to replace, paint the front end, frame, and engine. Then you can work on the cab in between while it's rolled back to do the work (as needed) underneath, then paint the bottom and roll it back into place. Then you can work on the interior of the cab, the back, any wiring inside and start cleaning the front-end sheet metal parts to get them reinstalled.
Thanks. I do get visits from some of the guys in the neighborhood checking to see how things are going.
As far as the oven cleaner... I have repainted my oil pan when I removed to check the screen and rod bearings. Will the oven cleaner hurt the paint job? Never used oven cleaner to clean the engine. I did see another post on here about the process, but again, I've never used it on a vehicle.
JWW
2004 F150 Crew Cab
