Parking brake removal
Teacherman
Post by Teacherman »
I dug through my Chilton's guide, but it was no help. :dk:
I need to remove the parking brake assembly in the cab to get to the floor vent behind it. The vent has six screws, and access to two of them are blocked by the parking brake. Why do I need to get to the vent? It won't close all the way because it is partially blocked with 30 years of pine needles and leaves which worked their way into the space between the cab and the engine space.
The brake seems to be held in place three ways -- a nut and screw into the bottom of the dash (easy enough) and then what appears to be two bolts attaching the brake to the front floorboard.
Any ideas?
1972 F250 Crew Cab
Family heirloom
Photo gallery: http://www.fordification.com/galleries/ ... ?cat=10482
69twotone
re: Parking brake removal
Post by 69twotone »
Hi Teacherman,
I do not know if this is what you are looking for when you say ideas but here goes.
I have taken vent assemblies off of a couple of junkyard trucks. You are right in order to get that last screw off you have to pull the bolts. Besides the one in the dash there are two that are on the firewall. You have to access them from the drivers side wheel well. If you take those off you can move it around enought to get to that last screw. It can be a pain if the bolts are rusted on. Reccomend soaking them with liquid wrench or something of the sort a littlle bit before pulling. If that does not work you can pull the cable too. and totally remove the assembly. I have not had to do so though.
Hope this is what you are looking for. :thup:
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
It's held to the bottom of the dash with a Phillips-head screw and nut, and then there are two studs on the back of the assembly that extend through the firewall, under the left-side inner fender. Just remove the nuts, and then the parking brake assy can be lowered enough to get it out of the way. (Don't mess with removing the cable.)
Teacherman
Cool. Thanks guys, I'll give that a try later this week.
1972 F250 Crew Cab
Family heirloom
1971ford
Re: re: Parking brake removal
Post by 1971ford »
I was about to post this exact thread in a few minutes, since today i was working on the truck and wanted to clean the cowl out of leaves.
FORDification wrote:It's held to the bottom of the dash with a Phillips-head screw and nut, and then there are two studs on the back of the assembly that extend through the firewall, under the left-side inner fender. Just remove the nuts, and then the parking brake assy can be lowered enough to get it out of the way. (Don't mess with removing the cable.)
how is this cable removed :?
i am going to repaint the cab and want it fully stripped. and it would be easier to grab leaves :D
is it a huge pain?
and how do you do it?
-Ryan
kaptnkaos
Post by kaptnkaos »
The easiest way I've found to remove the cable is to loosen the e-brake enough to get some slack on the end.
Then you can pull the cable out enough for the ball end to slip threw the notched hole in the e-brake assembly...
KaptnKA 8) S
bugser
Post by bugser »
kaptnkaos wrote:The easiest way I've found to remove the cable is to loosen the e-brake enough to get some slack on the end.
KaptnKA 8) S
Aaaahhhh yer just foolin'. I happen to know if you don't want it to come out,it will all by itself. :o
RON
Excuse me while I whip this out
the last truck i parted some idot from either the factory or some where else down the road had that stupid clip in backards. tell me that was easy to get out. i finally got it out bt it wasnt as easy as the others i've pulled off of the cable.
bugser
Post by bugser »
Wow, I would think they had to work at it to put it on backwards.
Sounds like my kinda mechanic. :evil:
RON
i kind of wonder how they might have done it myself. or if it could have somehow worked its own way around backwards. i was able to get it off sideways kind of. i had to work at it.
