Clutch and Brake pedals mechanics. 68 Ford F100
Noticed a lot of play in the clutch and brake pedals. I ordered new bushing from LMCTruck. I got the whole assembly out and was shocked to see how worn out everything was. In the bracket where the clutch/brake mount the grommets are completely worn through in fact worn down the bracket too. I can not find the parts I need anywhere so I am reaching out to the community for help.
In the bracket there are two grommets that hold the thin plastic bushings. I need to buy two new grommets, but can not find a part # anywhere. The drawings here on fordification show the part# for the bushing but the actual piece I need is greyed out and drawn with dotted line.
http://www.fordification.com/tech/image ... dals02.jpg
The part 2471 slides into these mystery parts. Also the drawing shows part 01508 this mystery part is attached to.
clutch / brake pedal grommets (mystery part#)
- Ranchero50
Re: clutch / brake pedal grommets (mystery part#)
There used to be a guy on eBay that sold a bearing repair for the mustang guys and they fit our trucks. Search Robroys build in the projects sub section for the details. I think they require some welding but it's not a big deal and is a pretty good repair.
